helicopter51
Oct 05, 2023Aspirant
raxe 300 router
Hello good evening I bought netgear raxe300 router and when i receive and try to conect to my provider isp sky no recognise the internet. what i need to do for the router can work. Kind r...
michaelkenward
Oct 06, 2023Guru - Experienced User
helicopter51 wrote:
As moden i bought new one that say is special for sky is Dray Tek vigor 167
The DrayTek Vigor 167 is a DSL modem.
Have you got that connected to the Internet?
You need to check that the he DrayTek Vigor 167 is in modem mode.
The manual (see above) explains how to do that.
helicopter51
Oct 06, 2023Aspirant
i configure the dray tek vigor 167 in mode of moden but when i plug the router no get signal said no internet.
So i call them and said i can used this router because i have residencial contract bla bla bla, and sure them lie.
i sure i can use just maybe is something that you need configure properly, maybe ip maybe dchp and no sure.
- michaelkenwardOct 06, 2023Guru - Experienced User
If you plug a PC into the modem, can you connect to the Internet?
What does "no get signal" mean?
What said "no Internet"?
What colour is the Internet LED on the top?
Can you access the router with a web browser and the graphical user interface (GUI)?
- helicopter51Oct 06, 2023Aspirant
when i plug my laptop o pc into the moden no internet because i buy this special modem for sky that you configure in mode bridge for can conect the router.
so for what i reading is i need configure the router in dchp opcion 61
no one know how to do it
- FURRYe38Oct 06, 2023Guru - Experienced User
Not sure if the RAXE has this option...I'd check the routers web pages under Advanced tab/Setup/Internet Setup or WAN setup.
Maybe a setting down under Advanced Tab/Advanced could be seen there.
