GlennPetti
Dec 25, 2023Aspirant
RAXE 300 router
Hello everyone, new here on the community, I have a problem with installing a brand new just bought RAXE 300 wireless router to my spectrum internet. Here are the details so bear with me, I have Sp...
Dec 25, 2023Guru - Experienced User
Has a power off for 1 minute then back ON with the ISP modem/router and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
1. Configure the modem for transparent bridge or modem only mode. Then use the NG router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ/ExposedHost or IP Pass-Through for the IP address the NG router gets from the modem. https://kb.netgear.com/25891/DMZ-on-NETGEAR-routers
https://kb.netgear.com/24086/How-do-I-set-up-a-default-DMZ-server-on-my-Nighthawk-router
3. Or disable all wifi radios on the modem and connect the NG router to the modem, LAN to LAN configure AP mode on the NG router.
https://kb.netgear.com/20927/How-do-I-change-my-NETGEAR-router-to-AP-mode
Try option #3 first...
https://kb.netgear.com/000061927/What-is-the-difference-between-router-mode-and-AP-mode
https://kb.netgear.com/26765/Disabled-Features-on-the-Router-when-set-to-AP-Mode
Connect a laptop or PC to the remote location to see if internet is accessible at the far end of the buried cable.
GlennPetti
Spectrum RAC2V2S Wireless router
- michaelkenwardDec 28, 2023Guru - Experienced User
That plus the RAXE300 adds up to two routers on your network, an arrangement that causes many of the problems that appear here.
Two routers on your network can cause headaches. For example, you can end up with problems with local IP addresses. Among other things, the other router can misdirect traffic that the Netgear router usually handles, such as routerlogin.net or the usual default local IP address for a router, 192.168.1.1.
This explains some of the other drawbacks.
What is Double NAT? | Answer | NETGEAR Support
Unless you have specific reasons for using two routers it is often easier to use just one router and to set up the second router as a wifi access point (AP) with a wired connection to the main router. Netgear advises this, as does just about every other site you will visit.How to fix issues with Double NAT | Answer | NETGEAR Support
It may be possible to put a modem/router into modem only (bridge) mode and then to use the second device as the router. Sometimes it is easier to put the second router into AP mode. But that has its own drawbacks:
Disabled Features on the Router when set to AP Mode | Answer | NETGEAR Support
