Alex49H
Feb 13, 2023Star
RAXE 500 disconnecting
I am currently on the newest firmware .94 and my RAXE 500 disconnects. After several reboots it does not connect to the internet.
- Feb 13, 2023
That would do it.
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
Feb 13, 2023Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
Use the MultiGig port or Standard Internet port to connect to the Modem/ONT?
Do you see any AMBER LEDs on top when this happens?
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch with a wired PC and web browser. Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
https://kb.netgear.com/24089/How-do-I-specify-the-pool-of-IP-addresses-assigned-by-my-Nighthawk-router
Alex49H
Feb 13, 2023Star
I am using my own modem, CM 2000 from Netgear and their cat5 ethernet cables.
- plemansFeb 13, 2023Guru - Experienced User
When it disconnects, what actually happens?
Does it say "connected, no internet"? Does it not broadcast wifi at all? Does it broadcast but you can't connect?
Do wired devices drop?
Do you have a screen snip of the modem's cable connection page and event logs?
- Alex49HFeb 13, 2023Star
I can connect to either 2.4 or 5 but it says no internet connection.
do you have the modem cable connections page and event logs?
If its connected to the router, you always need to ensure the router is getting a solid connection from the modem.
- FURRYe38Feb 13, 2023Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended. CAT6A STP if your using the multigig port between the RAXE and CM2000 for sure.
