Rune20
Dec 21, 2023Aspirant
RAXE Access Control Issues
This something new that started popping up yesterday. I'm not sure what this is? I just know it's causing major concerns. Since this has popped up, we noticed lagging in our network. Each time these ...
michaelkenward
Dec 21, 2023Guru - Experienced User
Have you tried a reset on your router?
How do I perform a factory reset on my NETGEAR router? | Answer | NETGEAR Support
It is probably the first step that Netgear support would suggest.
- Rune20Dec 21, 2023Aspirant
Hi. yes, I reset the router. I will watch for this issue to see if it pops up again.
