TVLN753
Oct 29, 2022Tutor
RAXE290 constantly drop different clients
RAXE290 constantly drop different clients Usually it looks like the following in the logs: [DHCP IP: (192.168.1.28)] to MAC address (my PC), Saturday, October 29, 2022 09:55:30 [WLAN access reject...
Oct 29, 2022Guru - Experienced User
1. what firmware is on the raxe?
2. what modem/gateway is the router connected to?
3. it only happens on the 5ghz? it doesn't drop on other bands? Have you tried changing what channel the 5ghz is broadcasting on?
4. if its only happening on 5ghz, are you using the DFS channels? or what channel are you using?
- TVLN753Oct 31, 2022Tutor
Firmware Version Check: No new firmware version available. Firmware Version V1.0.7.62_1
It is fiber modem located outside of the house in the box
It happens on both 2.4 and 5GHz. I have changed channels multiple times. 2.4 on old devises is extremely slow (kbps). My phone today dropped 5GHz signal every 2-3 min when I was streaming my security camera.
Mostly the default one which is 44 due to some devices do not see DFS channels.
- FURRYe38Dec 02, 2022Guru - Experienced User
Any progress on this?
- TVLN753Dec 02, 2022Tutor
Yes, after submitting debug logs and working as a router tester for 2 weeks for free I finally gave up. Bought Asus and returning RAXE290 soon.
