davidji
Dec 22, 2022Aspirant
RAXE290 regularly forgets ethernet LAN connection
My RAXE290 router regularly forgets my Windows 10 PC's ethernet LAN connection (while internet & wireless connections continue). This morning my connection lasted about 1 1/2 hours. Firmware versi...
Kitsap
Dec 22, 2022Master
davidji wrote:My RAXE290 router regularly forgets my Windows 10 PC's ethernet LAN connection (while internet & wireless connections continue). This morning my connection lasted about 1 1/2 hours.
Firmware version: v1.0.7.62_1, which seems to be the latest
When the connection fails, I try
ipconfig /releaseipconfig /renew
on the PC, but the renew command times out.
I need to reboot the router & issue renew again to get the PC back online.
When I do,ipconfig /all
shows lease expires in 24hrs.
PC in the same configuration worked fine with my previous router.
Things change. In the meantime you have a new router, Windows 10 gets operating system updates twice a month, and your PC manufacturer could have provided driver updates for your Ethernet port hardware.
On the PC, have you checked the properties of your Ethernet hardware to see if Windows is putting it to sleep under the power plan?
Don't forget to answer plemans questions.
