davidji
Dec 22, 2022Aspirant
RAXE290 regularly forgets ethernet LAN connection
My RAXE290 router regularly forgets my Windows 10 PC's ethernet LAN connection (while internet & wireless connections continue). This morning my connection lasted about 1 1/2 hours. Firmware versi...
Razor512
Dec 22, 2022Prodigy
While more of a rare issue, one other thing to check when the issue happens, is the using a separate device, head to the router page, and then check the "Attached Devices" section, and see if any other device is using the same LAN IP as your desktop PC.
michaelkenward
Dec 22, 2022Guru - Experienced User
Dontchaluv these "simple" networks?
