davidji
Dec 22, 2022Aspirant
RAXE290 regularly forgets ethernet LAN connection
My RAXE290 router regularly forgets my Windows 10 PC's ethernet LAN connection (while internet & wireless connections continue). This morning my connection lasted about 1 1/2 hours. Firmware versi...
davidji
Of the many things I've tried, the only thing that fixes this is a router reboot.
PC's ethernet is not put to sleep as part of a power plan. It's a desktop, and isn't setup that way.
Even if it were, I wouldn't a PC reboot, or
ipconfig /release
ipconfig /renew
wake it up? Neither helps here.
This changed exactly when I changed routers. The old one had flaky wifi, but the hardwired connections were flawless, this router is the opposite.
Ethernet goes away while I'm working on the PC
I tried swapping cables, but it made no difference. It works after a router reboot, then the router shuts down the port after some time.
And I checked router with the nighthawk phone app. It sees the PC as disconnected.
michaelkenward
Dec 22, 2022Guru - Experienced User
We don't know what those "many things I've tried" were – a PC reboot? – but, that can point to the modem in front of the router. What is it?
The fact that it was trouble free with an older router is not a reliable guide.
I can't find an answer to the questions from plemans
what modem/gateway is the router connected to
What happens if you reboot the computer
Are you using any switches/managed switches
This is slightly more reliable, but I have to agree with Kitsap . Did you actually check the setting? Windows can do unexpected things.
But there are other questions.
Don't put too much faith in that. Apps are designed to be "idiot proof" but they can fall over when anyone has a slightly complicated network.
- davidjiDec 22, 2022Aspirant
I finally found the quote option, so it's easier to reply to specific questions.
michaelkenward wrote:This is slightly more reliable, but I have to agree with Kitsap . Did you actually check the setting? Windows can do unexpected things.
There is no setting for that on this desktop PC. I checked that before I posted here. Nothing under devices, networking, or power.
davidji wrote:Of the many things I've tried, the only thing that fixes this is a router reboot.
Yes, PC reboot does nothing. Router reboot solves this temporarily. When the ethernet connection to the PC gets dropped, all the other devices still have internet access. Why would the modem matter? It's pretty old and I wouldn't mind if I need to replace it. I just don't see how it can be the culprit here.
RAXE290 is new, and I'm not yet convinced it works correctly.
- KitsapDec 22, 2022Master
davidji wrote:There is no setting for that on this desktop PC. I checked that before I posted here. Nothing under devices, networking, or power.
So you really did not check the setting. You simply could not find it.
What operating system does your PC run? Windows or iOS? If Windows, what version?
What operating system does your PC run? Windows or iOS? If Windows, what version.
I don't think it has such a setting. Windows 10.
