chrisc13
Apr 27, 2023Guide
RAXE300 5GHz Keeps dropping on broadcast and slow
RAXE300 - Firmware Version 1.0.8.64 5g keeps dropping out (2.4g is always okay. ) I tried different channels but still the same problem. Upgraded firmware twice, went back 1 version of firmwa...
- Apr 27, 2023
set your speeds at "up to 2400mbps".
When its set for "up to 4800mbps" it has to be 160hz wide and that uses the dfs channels.
If something is broadcasting on those channels, they have to switch off them and that can cause drops when it does so.
If you're in an area with DFS, I'd avoid those channels for stability.
chrisc13
Apr 27, 2023Guide
Setup:
All separate SSIDs for bands 2,5 + 6 , all broadcast
Enable 20/40/ MHz Coex - not selected
No Guest networks
No A security activated
No QoS
OFDMA on for 2.5 + 5
