chrisc13
Apr 27, 2023Guide
RAXE300 5GHz Keeps dropping on broadcast and slow
RAXE300 - Firmware Version 1.0.8.64 5g keeps dropping out (2.4g is always okay. ) I tried different channels but still the same problem. Upgraded firmware twice, went back 1 version of firmwa...
- Apr 27, 2023
set your speeds at "up to 2400mbps".
When its set for "up to 4800mbps" it has to be 160hz wide and that uses the dfs channels.
If something is broadcasting on those channels, they have to switch off them and that can cause drops when it does so.
If you're in an area with DFS, I'd avoid those channels for stability.
michaelkenward
Apr 27, 2023Guru - Experienced User
While many questions about routers are generic and could be answered anywhere, some things need specialist knowledge.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Nighthawk Routers with WiFi 6 (AX) - NETGEAR Communities
You might like to search there for messages related to your problem.
I will ask the Netgear moderator to move your message.
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
Check for various troubleshooting tips.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
chrisc13
Apr 27, 2023Guide
Many thanks for the quick reply , my first post here . Appreciate the move for me . Thanks
- plemansApr 27, 2023Guru - Experienced User
What actual channel do you have selected for the 5ghz?
Make sure to avoid any dfs channels as you can get drops if there's radar in your area.
Its only the 5ghz? 2.4 and 6ghz are fine?
- chrisc13Apr 27, 2023Guide
thank for the reply ,
Its only 5GH and channel = 06 , mode up to 600Mps
2.5 + 6 appear to be fine- michaelkenwardApr 27, 2023Guru - Experienced User
chrisc13 wrote:
Its only 5GH and channel = 06There is no Channel 06 on 5GHz. That's 2.4 GHz.
5GHz runs from 36 upwards.
