skywakkay202
Jan 22, 2024Tutor
RAXE300 6G is invisible to devices
Hi all, just bought 2 brand new RAXE300 and both are running Router Firmware Version V1.0.8.64_3 2.4G and 5G (WPA2-PSK) are working perfectly, However, the 6G (WPA3-PSK) SSID is on channe...
skywakkay202
Jan 23, 2024Tutor
Yes, 2.4, 5 and 6 leds are white and are on.
Here's my config:
Jan 23, 2024Guru - Experienced User
What if you change the channel to say 69 or 85 and also change the SSID name to say RAXE300-6G?
Try setting the Security to Enhanced Open temporarily as well. Then check.
Change back to WPA3 after checking.
