skywakkay202
Jan 22, 2024Tutor
RAXE300 6G is invisible to devices
Hi all, just bought 2 brand new RAXE300 and both are running Router Firmware Version V1.0.8.64_3 2.4G and 5G (WPA2-PSK) are working perfectly, However, the 6G (WPA3-PSK) SSID is on channe...
skywakkay202
Jan 30, 2024Tutor
all of that checks out. The Netgear lvl 2 tech support is on it for a week already. I have no idea what's going on. They have no Idea what is going on. Im thinking to return both of them. Maybe lemons?
Also - purchased on Amazon US but they came with region set to Canada and not allows you to change the region. Also - no transmit power selector in the menu. So weird.
Jan 31, 2024Guru - Experienced User
What region are you located?
I might try a different RAXE router from either Amazon or NG directly and see or try a different brand router with 6ghz support and compare. If different Router or branded router works, then would be something wrong with the 300 series routers.
