NetSond
Feb 13, 2024Star
RAXE300 and RAXE500 internet lights
I’m looking to purchase a RAXE300 or RAXE500, I’m wanting to Know if the internet light flashes when there is traffic flowing. Also does the WiFi and Ethernet lights flash the same way? I have the RA...
NetSond
Feb 15, 2024Star
Is this router not popular, I thought id ask the question on the forum instead of buying one and finding out, just don’t want to waste money
Feb 15, 2024Guru - Experienced User
Recent FW update has a few items missing or broke. NG has been made aware of it and said to put a fix forth in next FW update. I've enjoyed mine and works well. Have to find what works best for your needs and such. Always recommend trying something out and if it's doesn't work, return it. Find good places that have good refund policies. Like amazon.
Good Luck.
- NetSondFeb 15, 2024StarHi thanks for your reply
Very helpful that the router works well. Could you tell me if the internet light flashed before, and does it still flash with the recent firmware
Thanks again- FURRYe38Feb 15, 2024Guru - Experienced User
Internet LED doesn't blink.
No idea why different models have differences. Most of the time I guess, not really needed, As long as the color is WHITE and your seeing GOOD status on the routers web page, seems to be enough. I know some people are visual. I am but, also, I'm not looking at the router all the time so, as long as it's working, I'm good. 😉
We are talking about the RAXE300?
Did it ever flash on previous firmwares?
Thanks again
