niwat
Jun 30, 2023Aspirant
raxe300 buy from EU would like to change region to singapore, how to do ?
i order raxe300 from EU and bring router to use in south east asia, i would like to change wireless region from EU to singapore (region selection is gray) i know firmware base on where is the manufa...
schumaku
Jul 01, 2023Guru - Experienced User
The main reason where Netgear must suppress the region settings are the FCC regulations - so models sold in the US.
There is only one firmware for all markets.
What model id does your RAXE300 show on the back: Is it a RAXE300-100NAS (that would be a North American FCC version) or a RAXE300-100EUS? The RAXE300-100CNS is the version for the Chinese market, the RAXE300-100PAS is the version for the Asia-Pacific market.
niwat
Jul 01, 2023Aspirant
thanks for your help, but no word on the back side -100nas or -100eus or -100cns or -100pas
it's just say model raxe300 and have address netgear uk
- schumakuJul 01, 2023Guru - Experienced User
Well possible the manufacturer product designation isn't printed on the device. As you mentioned the Netgear UK mark, its a European model - with the hardware version -100xxx (what could vary) and the market designation -nnnEUS - this visible on the shipping box label only.
Worth a try to tweak the Web UI code as it was suggested before. And hope the change can be applied and saved, different from the FCC models.
- michaelkenwardJul 02, 2023Guru - Experienced User
It us on the box.
In older devices there is a "command line" option for changing the country. But they killed Telnet which ruled that out.
- schumakuJul 02, 2023Guru - Experienced User
michaelkenward wrote:In older devices there is a "command line" option for changing the country. But they killed Telnet which ruled that out.
For many years, Netgear supplies "world-wide" (WW) devices to most, AFAIK all markets except of FCC/US. The Web UI allowed to select the country/region resp. the regulatory area.
Considering the R7000 for example is in the market for not less than 10 years... I don't remember when this fancy shell (telnet) access was removed. We're becoming old michaelkenward
