cantara256
Jul 14, 2024Tutor
RAXE300: Combine 6Ghz band with 5Ghz/2.4Ghz?
I just setup a new RAXE300 6E router. I used SmartConnect to combine the 2.4Ghz and 5Ghz bands, but it won't include the 6Ghz band. I used the same SSID for both the combined 2.4/5Ghz bands, and ...
- Jul 15, 2024
So I reset my phone's WiFi settings (i.e. made it forget everything), and now it works fine: it seamlessly switches between 5GHz/6GHz on the same SSID.
I talked to Netgear tech support, and it's ok to have the 6GHz band share the SSID as the combined SmartConnect bands. No real explanation why SmartConnect can't include 6GHz.
Jul 15, 2024Guru - Experienced User
I've got the RAXE500 and the 6ghz doesn't integrate with the smart connect either. One of the biggest disappointments about it. I've asked a moderator about if there was an intention to integrate it but I didn't hear anything back. I'd expect the RAXE300 to be similar.
cantara256
Jul 15, 2024Tutor
