Davidgear2
Oct 11, 2026Aspirant
RAXE300 DNS failover failure — secondary DNS unreachable when primary fails
Product: NETGEAR Nighthawk RAXE300 (AXE7800) Firmware: V1.0.9.82_1 IPv6: Disabled Date tested: 11 October 2026 Hi all, I'm using a local dns as my primary and a remote (confirmed working) ...
Oct 14, 2026Guru - Experienced User
How often is the pi going down? Might start there.
Anything the system fully depends on, should have a battery backup and be pretty close to bulletproof.
One of the othe reasons I moved away from the pihole method.
