Davidgear2
Oct 11, 2026Aspirant
RAXE300 DNS failover failure — secondary DNS unreachable when primary fails
Product: NETGEAR Nighthawk RAXE300 (AXE7800) Firmware: V1.0.9.82_1 IPv6: Disabled Date tested: 11 October 2026 Hi all, I'm using a local dns as my primary and a remote (confirmed working) ...
Davidgear2
Oct 19, 2026Aspirant
netgear your forum show more button is subtle!
FrumpyGrandpa still on the to do
plemans it hasn't gone down, I'm just covering myself with an online solution in case the hardware(pi not router) got knocked/unplugged/broken or the software crashes/bugs/goes weird. what do you use? for my use case battery backup would be excessive.
Oct 19, 2026Guru - Experienced User
I actually used a Raspberry Pi for a year or two and then switched to a Docker-based version of the Raspberry Pi. It worked really well but didn't
include the full details I wanted for my system, so I ended up buying a cheap mini-PC and running an OPNsense router on it with Unbound (basically the same as a
Raspberry Pi with recursive DNS). It's worked well and helped with the stability of my network.
But I do use a backup power supply that includes the modem and router. Nothing expensive because our power doesn't go out for long. I think it's a cheap APC, $60-80, and it's worked great. Highly recommend it when you run your own DNS or have DNS filtering.
