amutimer
Jan 12, 2024Aspirant
RAXE300 does not connect to the internet
Hi Guys, I fear I may be about to show my ignorance, please bear with me. I am with Vodafone using a full fibre connection from Cityfibre. Windows11 The system works fine with the Vodafone ...
Jan 12, 2024Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended
If your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
1. Configure the modem for transparent bridge or modem only mode. Then use the NG router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ/ExposedHost or IP Pass-Through for the IP address the NG router gets from the modem. https://kb.netgear.com/25891/DMZ-on-NETGEAR-routers
https://kb.netgear.com/24086/How-do-I-set-up-a-default-DMZ-server-on-my-Nighthawk-router
3. Or disable all wifi radios on the modem and connect the NG router to the modem, LAN to LAN configure AP mode on the NG router.
https://kb.netgear.com/20927/How-do-I-change-my-NETGEAR-router-to-AP-mode
Try option #2 first...
Power OFF both ISP modem and RAXE router. for 1 minute then back ON with the ISP modem and give 30 seconds then ON with the RAXE router...
- amutimerJan 13, 2024Aspirant
Hi,
By digging around I believe I have found my problem.
It makes no sense to me, but I have found out that CityFibre/Vodafone require you to tag the WAN port - yes, the WAN port - with 611.
I see no way to do that on the RAXE300. Does anyone here know if it can be done?
Adrian
- michaelkenwardJan 13, 2024Guru - Experienced User
Not sure what that means. Over to the network experts.
Have you tried running the RAXE300 through the Internet setup wizard?
Did you try this?
I find it hard to believe that Vodafone has a system that doesn't allow third party routers on to the network.
Is there a Vodafone user community that you could consult?
Yes, I have tried all the methods; using the phone app, also using the "genie" on the browser, and also doing it manualy.
Cityfibre/Vodafone have not made it impossible to use a third party router, but the router must be able to join the Cityfibre network (numbered 911) by use of VLAN, and I am not clear that the RAXE300 can do this.
I believe the reason Cityfibre/vodafone require you to join the 911 VLAN is because they also sell TV services (or they may want to later) and they want to be able to separate the TV services from the normal internet service and they do so by having two VLANs so it becomes necessary to be specific which one you are joining.
It is therefore essential to be able to do this with your router...
I have tried this
https://kb.netgear.com/25724/VLAN-tagging-setup-for-Nighthawk-router#
and I have tried two rules. But neither worked.
Given that Voda/City are all over England this must be happening to thousands of users. But I cannot find a bespoke fix anywhere.
Anyone here know?
A
