1phish
Nov 03, 2024Aspirant
RAXE300 End of Life?
Is the RAXE300 readily supported with updates or is it end of life? The last firmware is from 2023.
1phish
No. But I'm more focused on the security aspect, like vulnerabilities. A whole year without any patches makes me wonder if it's EOL or not, if that makes sense.
Nov 03, 2024Guru - Experienced User
Have you experienced any vulnerabilities on the RAXE?
NG has a site to submit them if you see something...
- 1phishNov 03, 2024Aspirant
strictly interested in making sure the device is getting the updates it needs, to restate it hasn't received an update since 2023.
- FURRYe38Nov 04, 2024Guru - Experienced User
Unless there is a major problem or vulnerability, NG doesn't tend to push updates frequently to any router model.
