Johnw98
Jul 31, 2024Follower
Raxe300 keeps dropping and losing internet port ip addresses
Have had this router for a month now, since then it’s been the biggest headache. Daily it will drop internet and come back. But every few days it does a hard drop and I’ll have to pray rebooting it a ...
michaelkenward
Jul 31, 2024Guru - Experienced User
Are you looking for help with this router?
If so, let's start with the usual boilerplate questions to eliminate some of the more common issues that crop up here.
What firmware version do you have on the device?
A number is more useful than "the latest". There may be newer versions, or "hot fixes", that do not show up if you check for new firmware with an app or in the browser interface.
If there is one it might also help if you told people the make and model number of the modem/gateway/ONT that connects this router to the Internet. Is it, by any chance, also a router, with a set of LAN ports on the back?
I ask because a lot of people turn up here trying to put a router behind a modem that is also a router. That can complicate troubleshooting.
Apologies for all the questions. But you can help people to help you by providing the information suggested in this forum's header:
Subject (Include model number and brief summary)
Model (Recommended - Helps the community give the best answers)
Body (Include additional detail including model version, firmware, OS and environment where relevant.)
They are there for a good reason.
