Newport92663
Apr 12, 2024Aspirant
RAXE300 lost connection to Spectrum Modem
I have a RAXE300 and Spectrum Modem. It has been working flawlessly for a few moths. Today at midnight it "lost" connection with the cable modem. By that I mean I do not get a connection via wirel...
- Apr 12, 2024
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.Was the Internet LED on top of the RAXE router amber when this happened?
Armor, Smart Parental Controls or Circle, Traffic Meter.
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
Apr 12, 2024Guru - Experienced User
Newport92663
Per the recommendation, I started the sequnce per instructions and it worked. Thank you for providing the solution.
