HoosierGuy88's avatar
HoosierGuy88
RAXE300 Nighthawk Network Options for Wired Connection
I recently purchased the Nighthawk RAXE300 tri-band router. I was hoping it would improve my wireless download speed for a few gaming devices (Xbox Series X and PlayStation 5). It did not.
It seems like I will need to hardwire the devices but my router is not close to those devices. Are there any network extenders that also have Ethernet out, which will get my close to 1gbps download speeds on Ethernet?
I researched a bit and saw a mesh system with “satellites” but they do not appear to work with this router, only the specific mesh system.
In general, the router is in the same room as the systems i am trying to improve download speeds on, so WiFi strength should be fine. But to connect an Ethernet cable would require routing 100’ of Ethernet along baseboards around the room.
I have other devices in other rooms I would like to extend WiFi network to as well, so may need to purchase a few extenders.
    Sounds like a powerline adapter would be a good solution for your application.  Go on to Amazon and do a search for Netgear Powerline Adapters.  There may be some users here that will provide some favorite model numbers.
    The powerline adapter kits provide both Wi-Fi connections and Ethernet ports.
    • HoosierGuy88's avatar
      HoosierGuy88
      I have tried powerline adapters with my old router and it was worse than WiFi. Could only get 100mbps down, whereas with WiFi I get around 200mbps. I have 1gbps service, and when wired usually get close to that.
      • Kitsap's avatar
        Kitsap
        Master
        Your experience is contrary to that of many.  The powerline extenders do not work well for everybody.  The quality of the home electrical wiring plays a significant role in the performance. I do not know how long ago your experience was, possibly newer design products have improved.
