Schwacker
Dec 07, 2023Aspirant
RAXE300 No Internet Connection
Hi Everyone, I woke up, this morning, to find my Nighthawk RAXE300 not able to get on the internet. My Internet LED is solid orange. It was working fine, yesterday, so I'm a bit confused on wha...
- Dec 07, 2023
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
Schwacker
Michael - thank you for the quick feedback and I am surprised (though I shouldn't be) for I had thought I had the latest firmware. In the past, I would like on the Check for Update within Netgear software and it would always tell me I have the latest firmware.
Well, based on your advice, I went to Netgear support page and discovered there is a new firmware version!! I downloaded it and updated the firmware manually. Rebooted my router and PC -- I AM ONLINE! I AM ALIVE!
Again, thanks for the advice!
Dec 07, 2023Guru - Experienced User
Enjoy. 📡
