oboeadam
Mar 05, 2025Aspirant
RAXE300 No internet
Hi everyone, I'm having what looks like the same problem as a few people with this product. The router works fine until suddenly the internet LED is solid amber. Xfinity reporting no outages or ...
- Mar 05, 2025
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
oboeadam
Solved:
Did the full factory reset and we're back up.
Mar 05, 2025Guru - Experienced User
Enjoy. 📡
