nuteksystems
Feb 15, 2024Tutor
RAXE300 not connecting wifi 6
I have a new laptop with a Realtek RTL8852BE-VS WiFi 6 802.ax card in it. I am using Windows 11 Home and all NIC and Windows updates are current. No matter what settings I use for WiFi 6 the rout...
Feb 15, 2024Guru - Experienced User
What region are you located?
No matter what settings I use for WiFi 6 the router refuses the connection. Windows can see the network and after putting in the password it say "cannot connect to this network" The password is correct.
Why?
- nuteksystemsFeb 15, 2024Tutor
USA, I bought an Intel AX210 Tri-band.
