nuteksystems
Feb 15, 2024Tutor
RAXE300 not connecting wifi 6
I have a new laptop with a Realtek RTL8852BE-VS WiFi 6 802.ax card in it. I am using Windows 11 Home and all NIC and Windows updates are current. No matter what settings I use for WiFi 6 the rout...
Feb 15, 2024Guru - Experienced User
What region are you located?
No matter what settings I use for WiFi 6 the router refuses the connection. Windows can see the network and after putting in the password it say "cannot connect to this network" The password is correct.
Why?
nuteksystems
Feb 15, 2024Tutor
USA, I bought an Intel AX210 Tri-band.
