nuteksystems
Feb 15, 2024Tutor
RAXE300 not connecting wifi 6
I have a new laptop with a Realtek RTL8852BE-VS WiFi 6 802.ax card in it. I am using Windows 11 Home and all NIC and Windows updates are current. No matter what settings I use for WiFi 6 the rout...
michaelkenward
Feb 15, 2024Guru - Experienced User
nuteksystems wrote:
No matter what settings I use for WiFi 6 the router refuses the connection. Windows can see the network and after putting in the password it say "cannot connect to this network" The password is correct.
Have you set the router to show 6 GHz as a separate SSID?
NetSond
Feb 19, 2024Star
Try setting the SSID separate 2.4, 5 and 6 as different names
