OmegaStrife
Nov 11, 2024Aspirant
RAXE300 Not Port Forwarding Correctly?
So I used to have a RAX80 which would forward ports completely fine, but I upgraded to the RAXE300 (Netgear Nighthawk) and it does not appear to be forwarding ports as I am intending. I tried as many...
- Nov 22, 2024
Yes, apologies. It turned out it was a very confusing issue with Windows Firewall. I had allowed permissions for the program, for ports, and various other settings but it never resolved until I just turned it into accepting all ports. I believe the router was working as intended the whole time. However, the issue occurred when I replaced the Nighthawk router that I had, so I have no idea why Windows Firewall started interrupting the process when I hadn't changed any settings. Mystery solved, I guess. I tore my hair out over this for about 4-5 days.
DarrenM
Nov 20, 2024Sr. NETGEAR Moderator
I would first try removing all the port forwarding but the 9987 and 30033 are the 2 ports that are required for Teamspeak and see if that works. You may also want to run the server as Admin when you boot it up on whatever device you use it.
Thanks
Darren
