JD1203
Jun 23, 2024Aspirant
RAXE300 slow connections
Started having speed problems with my RAXE300. Was getting 500+Mbps, all of a sudden, barely get 8Mbps on either wifi or wired. Latest firmware V1.0.7.62_1. It's connected to CM700 with supplied wire....
- Jun 26, 2024Solved: as a last resort I did a factory reset. Back to normal speeds, just a pain to have to put everything back in.
michaelkenward
Jun 23, 2024Guru - Experienced User
There is a logical process in tracking down this sort of problem.
First, restart the network.
- Turn off and unplug modem.
- Turn off router and computers.
- Plug in and turn on modem. Wait 2 minutes for it to connect.
- Turn on the router and wait 2 minutes for it to connect.
- Turn on computers and rest of network.
