wildwestman
Aug 17, 2022Guide
RAXE300 slow ReadySHARE USB SSD speeds
Hello, just got the RAXE300 and generally i think that it is a great router and i like the WiFi 6E speeds. My PC is connected to the router (Intel AX210) with 2402/1922 (Mbps) speeds which is nic...
CD_router_888
Aug 23, 2022Guide
Could you share more details like,
1. What's your HDD/ SSD brand ?
2. What kind of connected interface it is? TypeC/ USB3.0/ HSB2.0 ?
3. When you transfer the file from PC to readyshare, did you also running other application or playing the games ?
wildwestman
Aug 23, 2022Guide
My main USB SSD for storage is a Crucial X8 2TB drive. It is USB type C. I have tried two other USB drivers, one HDD and another SSD with the same result. So it is not a specific USB drive issue.
No, i did not run any other applications or games but that honestly does not matter. I am doing the exact same 1:1 scenarios as I used with the XR500 where i got over 60mb/s.
The interesting this is is that copying data to the PC from the readyshare drive, i get 90mb/s which is what i would expect.
Another thing is that when i change to the 6GHz network, even that the link speeds 2402/2402(Mbps) reported by windows look better then on the 5GHz network, the write speed drops to around 30mb/s which is even worse.
