and00r
Nov 19, 2023Aspirant
RAXE300 Transmit Power Control
Hello, I first tried searching here for this topic but nothing came up for me.
The "Transmit Power Control" option for wifi seems to be missing on my RAXE300 router running the latest firmware.
No settings for this within the user web interface, or the Nighthawk app.
Strangely, the user manual for the RAXE300 does include these options, listed on page 80.
Any help would be appreciated
Sort By
Could it be hidden in the debug zone?
http://routerlogin.com/debug.htm
If it was there in earlier firmware, perhaps it was removed. If it is essential, you may have to track down the latest version that supports it.
- and00rAspirant
Unfortunately there are no options for adjusting the Transmit Power Control within the debug menu.
And reverting to an older version of firmware is not an option for me, as I would have to remain on this older version of firmware, as upgrading would then remove any previous Power Control options set, and revert the transmit strength back to 100%
I suppose there is not much anyone could do about this.
Thanks for the help though.
What does make you so convinced the previously manual set power limits set are retained in place with the update?
Which regulatory area are you operating your RAXE300 in?
I find it more than strange the manual controls have been removed from the Web UI. Agree with your point there is not much we can do about it, except of continue to ask questions. DarrenM plese.
