cluelesstechy
Apr 03, 2024Aspirant
RAXE300 Tri-band Wifi Router - can't connect to the internet
Hi, I have an office located in a Costco warehouse. We are trying to get Wifi in the office. I was trying to follow the instruction on the Nighthawk app, and the web interface, the problem I run ...
cluelesstechy
Apr 12, 2024Aspirant
Thanks for the advice. I had no luck with making the router an AP. As you suggested, I'll have to reach out the offices IT department to see what is happening.
Kitsap
Apr 12, 2024Master
cluelesstechy wrote:Thanks for the advice. I had no luck with making the router an AP. As you suggested, I'll have to reach out the offices IT department to see what is happening.
Do you mean you could not get the router configured for AP mode or once in AP mode, you could not get an internet connection through the Ethernet port in the office?
- cluelesstechyApr 16, 2024Aspirant
There was no internet access through the ethernet cable once i got the router configured to AP mode.
I spoke to the online IT help centered, and they said that everything is open on their end. Not sure what else I can do.
- FURRYe38Apr 16, 2024Guru - Experienced User
When you configure AP mode on the RAXE, are you using a dynamic or static IP address configuration for this mode?
I'm not sure. I'm not familiar with the difference between static and dynamic. They gave me a range of IP addresses that I could use to try and manually configure the AP mode.
