McGallagher275
Oct 05, 2026Follower
RAXE300 V1.0.9.82 periodically losing DHCPv4 WAN lease.
My RAXE300 on V1.0.9.82 periodically loses its Spectrum DHCPv4 WAN lease. WAN status becomes 0.0.0.0 while IPv6 remains operational. Rebooting only the RAXE300 immediately restores the public IPv4 ad...
Oct 06, 2026Guru - Experienced User
Brand and model# ISP modem that the RAXE is connected too?
CAT# LAN cable used between the ISP modem and RAXE router? CAT6A STP is recommended.
If you disable IPv6, does IPv4 on the WAN side still drop?
Not sure when new FW will be posted. Might try going back a prior Fw version to see if this helps any...
