kmeifert
Oct 19, 2024Aspirant
raxe300 will not connect to my main router using the 2.5 gb ethernet port
I have an raxe300 router setup as an acess point. Was trying to connect it to the main router (rs600) using the 2.5 gb ethernet ports on both devices...but the raxe300 will only connect to the i...
Oct 21, 2024Guru - Experienced User
What happens if you configure the RAXE for router mode, configured the 2.5Gb Multi Gig port for the main internet port, apply the change, then configure AP mode, apply the change then connect the 2.5Gb port to the RS?
