Blachowiak
Sep 21, 2024Aspirant
RAXE300 will not save short preamble for 5/6ghz
I am unable to set and save the short preamble preamble mode for 5GHz or 6GHz. This issue has been raised in other posts for other routers. I can't find any resolution. Router: RAXE300 Firmware...
Sep 21, 2024Guru - Experienced User
Maybe due to that 5 and 6Ghz may not support that feature...
Blachowiak
Are you saying that the option to select the preamble mode is not a supported feature? All three WiFi bands have their own drop down menu for this mode.
- FURRYe38Sep 21, 2024Guru - Experienced User
And when short preamble is selected and you select apply, what is happening?
- BlachowiakSep 21, 2024AspirantThe router resets as if it is applying the preamble mode setting selection. When I navigate back to the "advanced setup" -> "wireless settings" page the preamble mode is "long preamble".
- FURRYe38Sep 23, 2024Guru - Experienced User
I'd try a factory reset and setup from scratch using a wired PC and web browser:
https://kb.netgear.com/22697/How-do-I-install-my-NETGEAR-router-using-the-router-web-interface
Try MS Edge or Firefox browsers.
Then check the short preamble setting to see if it persists or not.
Is the router working otherwise?
There a reason why you want to change to short vs long?
