isaaccoo
Sep 30, 2022Star
RAXE450 5GHz band averaging 750-950 Mbps
I have a Dell equipped with an Intel Killer Wireless 1650 Wi-Fi Card which supports up to 2.4 Gbps @ 160Mhz on the 5GHz ax band. I regularly use this laptop and get 1400-1600 Mbps in the office and o...
Oct 01, 2022Guru - Experienced User
A couple things.
1. did you check to see if the wan port was connecting at the 2.5gig connection?
https://kb.netgear.com/24222/How-do-I-display-Internet-port-statistics-on-my-Nighthawk-router
2. Even though the router has a 2.5gig port, it only has 1x. So if you're modem is using the 2.5gig port, the other hardwired devices are using the 1gig ports (unless your using lan port aggregation). So those hardwired devices will max out at the 1 gig
3. when speedtesting wireless, did you try other channels on the 5/6ghz? Plus you need to be close to it as those speeds will drop off quickly.
4. what firmware is on the RAXE450?
isaaccoo
Oct 01, 2022Star
1
