isaaccoo
Sep 30, 2022Star
RAXE450 5GHz band averaging 750-950 Mbps
I have a Dell equipped with an Intel Killer Wireless 1650 Wi-Fi Card which supports up to 2.4 Gbps @ 160Mhz on the 5GHz ax band. I regularly use this laptop and get 1400-1600 Mbps in the office and o...
Razor512
Oct 02, 2022Prodigy
For the WiFi client devices, what was the PHY rate of their connection?
If in the same room and on the 5GHz band with the AX features turned on, it should look like this.
On your specific WiFi adapter, it should give you around 1.8Gbps real world throughput from a 2402Mbps PHY rate, though there are exceptions. If extremely close to the router, e.g., within around 8 or so inches, speeds can drop due to receiver overload leading to corrupt frames, thus the router will get a ton of overhead from frame re-transmissions, common on any AP that uses attempts to use a full watt of transmit power, though if using DFS channels, due to extreme FCC restrictions, they get forced down to 250mW which can be used at closer distances.
Outside of that, also head to the router page, and click on the "Advanced" tab, and then click on "Show Statistics".
Make sure the 2.5GbE port is showing a status of "2500M/Full"
- isaaccooOct 03, 2022Star
For the PHY, I got:
- Protocol: Wi-FI 6 (802.11ax)
- Security type: WPA2-Personal
- Network band: 5 GHz
- Network Channel: 44
- Link speed (Receive/transmit): 1922/1470 (Mbps)
- Manufacturer: Intel Corporation
- Description: Killer(R) Wi-Fi 6 AX1650s 160MHz Wireless Network Adapter (201D2W)
- Driver version: 22.160.3.2
In the router, went to Advanced / Advanced Home / Internet Port / WAN Preference = Multi-Gig Port (2.5/1 Gbps).
I tested this router at many ranges, mainly:10ft, 6ft, 3ft, 1ft. 1in, and when i planted it on the laptop.
Anything else I can provide to help with this?
- CD_router_888Oct 04, 2022Guide
- isaaccooOct 05, 2022Star
I don't see any limits set.
Here's the QoS settings with speed test results:
Here's the speed test from my PC:
Here are the Wifi Settings on my PC:
Protocol: Wi-Fi 6 (802.11ax)
Network band: 5 GHz
Network channel: 44
Link speed (Receive/Transmit): 1922/1441 (Mbps)
