isaaccoo
Sep 30, 2022Star
RAXE450 5GHz band averaging 750-950 Mbps
I have a Dell equipped with an Intel Killer Wireless 1650 Wi-Fi Card which supports up to 2.4 Gbps @ 160Mhz on the 5GHz ax band. I regularly use this laptop and get 1400-1600 Mbps in the office and o...
isaaccoo
Oct 03, 2022Star
For the PHY, I got:
- Protocol: Wi-FI 6 (802.11ax)
- Security type: WPA2-Personal
- Network band: 5 GHz
- Network Channel: 44
- Link speed (Receive/transmit): 1922/1470 (Mbps)
- Manufacturer: Intel Corporation
- Description: Killer(R) Wi-Fi 6 AX1650s 160MHz Wireless Network Adapter (201D2W)
- Driver version: 22.160.3.2
In the router, went to Advanced / Advanced Home / Internet Port / WAN Preference = Multi-Gig Port (2.5/1 Gbps).
I tested this router at many ranges, mainly:10ft, 6ft, 3ft, 1ft. 1in, and when i planted it on the laptop.
Anything else I can provide to help with this?
CD_router_888
Oct 04, 2022Guide
- isaaccooOct 05, 2022Star
I don't see any limits set.
Here's the QoS settings with speed test results:
Here's the speed test from my PC:
Here are the Wifi Settings on my PC:
Protocol: Wi-Fi 6 (802.11ax)
Network band: 5 GHz
Network channel: 44
Link speed (Receive/Transmit): 1922/1441 (Mbps)
