guccia123
Jan 19, 2025Aspirant
RAXE450 6Ghz Problem (can't find from any device)
Hi, I just purchased Netgear RAXE450 but seem to have issue with 6Ghz. I have lots of devices around and none of them seem to find it. S21 Ultra, S22 Ultra, Laptops with AX211 cards. ...
Jan 19, 2025Guru - Experienced User
What region are you located? I believe there is a issue with 6Ghz working in other regions outside of the NA region...
What 6Ghz channel are you setting.
WPA3 is the security mode.
What SSID name are you using? Be sure to try a simple character SSID name for 6Ghz.
guccia123
I'm in Georgia Country but Router is US model. Phones and all tech is from USA. 6GHz channel tried using almost all channels both PSC and non-PSC. Different connection speeds. Security mode both Open and WPA3. SSID is GM - 6GHz.
- FURRYe38Jan 19, 2025Guru - Experienced User
Try GM6Ghz for SSID after getting the unit back to a USA region.
If this all fails, I'd return the unit as defective. 6Ghz should be working...
