guccia123
Jan 19, 2025Aspirant
RAXE450 6Ghz Problem (can't find from any device)
Hi, I just purchased Netgear RAXE450 but seem to have issue with 6Ghz. I have lots of devices around and none of them seem to find it. S21 Ultra, S22 Ultra, Laptops with AX211 cards. ...
guccia123
I'm in Georgia Country but Router is US model. Phones and all tech is from USA. 6GHz channel tried using almost all channels both PSC and non-PSC. Different connection speeds. Security mode both Open and WPA3. SSID is GM - 6GHz.
Jan 19, 2025Guru - Experienced User
Try GM6Ghz for SSID after getting the unit back to a USA region.
If this all fails, I'd return the unit as defective. 6Ghz should be working...
