coolwifi's avatar
coolwifi
Luminary
Feb 17, 2025
RAXE500 - 2.4 Ghz and 6 Ghz RSSI fluctuations standing next to the router
The 2.4 Ghz and 6 Ghz wifi RSSI seem to fluctuate a bit, with 6 Ghz fluctuating more sometimes up to +/- 10 dbm even standing next to the router. Looks like both the 2.4 and 6 Ghz band antennae are in the right wing of the router. Changing the channels didn't help Is the router defective? Got this router in a deal for 271 bucks and thinking of returning it.
Also the latest firmware causes inconsistent latency spikes in both wired and wireless connections to the router. I had to downgrade the firmware to prevent this latency issue. Is it wiser to get the RS series instead?
    • coolwifi's avatar
      coolwifi
      Luminary
      I looked at the same article before. the 5 Ghz RSSI doesn't vary much, may be +/- 2 dbm next to the router. The large fluctuation only happens in the 2.4 and 6 Ghz band RSSI. Is there anything defective with the right wing antennae of the router?
    • coolwifi's avatar
      coolwifi
      Luminary
      plemans Do you think that 5-10 dbm variation in RSSI standing next to the router is normal in the 6 Ghz band? The 6 Ghz band is barely useable in this router unless you are in line of sight of the router within 10-15 ft.
      • plemans's avatar
        If you feel its an issue with the device, feel free to open a support case with netgear if its in warranty. If its new, sometimes its faster to exchange it where you bought it
