JohnInAtlanta's avatar
Sep 15, 2023
RAXE500 - Can I use VLAN tagging to isolate one physical port?
I am using an RAXE500 as the centerpiece of a home network.  Is it possible to configure this router (VLAN?) to isolate one of the physical Ethernet ports from the rest of the network but allow it to...
  • FURRYe38's avatar
    Sep 15, 2023
    I believe VLAN tagging is for ISP services only from the WAN side. Router doesn't have any VLAN tagging support on the LAN side. Thats mostly seen on managed LAN Switches.
