ClaytonJ2
Jun 06, 2021Aspirant
RAXE500 - Disney Circle missing and Armor disconnects internet
I got the Nighthawk RAXE500 yesterday. I had a hard time setting it up because the web page interface on my PC doesn't have as much functionallity as it did with my old router. I'm a PC guy. I don't ...
- Jun 08, 2021
Hi ClaytonJ2,
Thanks for confirming. The RAXE500 currently does not support Circle Smart Parental Control features. I have included an article below that has a list of NETGEAR routers that support Circle.
https://kb.netgear.com/000044718/Which-NETGEAR-routers-support-Circle-Smart-Parental-Controls
I'd like to have your concerns regarding Armor escalated. May you send me a private message with your email and serial number.
Thanks,Christian
Christian_R
Jun 08, 2021NETGEAR Employee Retired
Hello ClaytonJ2,
Welcome to the community! Thank you for taking the time to share your experience. I'd like to help address some of the issues you're experiencing. First things first, may you check to see if you're on the latest firmware version for the RAXE500. I have linked the latest firmware version below.
https://kb.netgear.com/000063717/RAXE500-Firmware-Version-1-0-5-62
Christian
- ClaytonJ2Jun 08, 2021Aspirant
Yes, that is the firmware version of my router.
My Router:Nighthawk RAXE500 Firmware Version V1.0.5.62_2.0.35NETGEAR Nighthawk AXE11000 Tri-band WiFi 6E Router (RAXE500)
- Christian_RJun 08, 2021NETGEAR Employee Retired
Hi ClaytonJ2,
Thanks,Christian
