GCFalcon1989
Mar 06, 2024Aspirant
RAXE500 - Multiple devices in "Attached Devices" with different subnet
I have a RAXE500. Latest firmware ( V1.2.13.100_2.0.54). I have the subnet range set at 192.1.168.xxx, but for some reason, there are several devices that show up in the 10.0.0.x range. This is ha...
Retired_Member
Mar 06, 2024the Xfinity gateways for example use 10.0.0.1 subnet by default.
possibly your wifi is connected to your ISP gateway
while your ethernet is plugged into the RAXE500 with its 192.168 subnet.
tip: maybe best, you put your ISP gateway in "bridge" mode.
(else put the RAXE500 in AP mode, take your choice, if that's the issue)
