GCFalcon1989
Mar 06, 2024Aspirant
RAXE500 - Multiple devices in "Attached Devices" with different subnet
I have a RAXE500. Latest firmware ( V1.2.13.100_2.0.54). I have the subnet range set at 192.1.168.xxx, but for some reason, there are several devices that show up in the 10.0.0.x range. This is ha...
Mar 06, 2024Guru - Experienced User
What mode is the RAXE working in? Router or AP mode?
GCFalcon1989
Thank you for the reply!
The router is working in router mode.
The modem is a Nighthawk CM2050V (self purchased and configured remotely via my ISP (Infinity)).
- Retired_MemberMar 06, 2024
what is the wifi network name (SSID) you're seeing with the 10.0 /16 subnet IP address?
maybe you've inadvertently connected to a nearby Xfinity hotspot?
- FURRYe38Mar 06, 2024Guru - Experienced User
Well theres no router in the CM series of modems so different subnet would not be coming from that.
Can you show us a picture of what your seeing on the RAXEs web page for connected devices? Redact any MAC addresses before posting.
