JaegerOmega
Jan 31, 2022Aspirant
RAXE500 - Network USB Doesn't Work
I just connected my RAXE500 and wanted to set up the USB drive on readyshare that I previously used on my older Nighthawk but it doesn't seem to work. I went to the Advanced settings and shut off all...
JaegerOmega
Feb 01, 2022Aspirant
When I tried this it wouldn't connect.
Razor512
Feb 01, 2022Prodigy
What error does it give when you use the router's IP address?
- JaegerOmegaFeb 01, 2022AspirantConnection refused
- Razor512Feb 01, 2022Prodigy
I wonder if the network browser function is disabled in windows, or if the network was mistakenly identified as public rather than private by the windows firewall thuus disabling the file sharing functions.
What happens if you click on the network folder in the lefthand column in the file explorer?- JaegerOmegaFeb 01, 2022AspirantI'll check that when I get on next. Rough few days didn't even think of that.
