JaegerOmega
Jan 31, 2022Aspirant
RAXE500 - Network USB Doesn't Work
I just connected my RAXE500 and wanted to set up the USB drive on readyshare that I previously used on my older Nighthawk but it doesn't seem to work. I went to the Advanced settings and shut off all...
Razor512
Feb 01, 2022Prodigy
Did it work before any changes to the share name took place? If it is happening to multiple systems, it may be worth doing a factory reset.
JaegerOmega
Feb 01, 2022Aspirant
Interestingly I can see the RAXE500 device under Network Locations. When I click on it and then click Browse Folders I can see the network drive folders...
- JaegerOmegaFeb 01, 2022AspirantNevermind it's not doing it anymore :(
