JaegerOmega
Jan 31, 2022Aspirant
RAXE500 - Network USB Doesn't Work
I just connected my RAXE500 and wanted to set up the USB drive on readyshare that I previously used on my older Nighthawk but it doesn't seem to work. I went to the Advanced settings and shut off all...
JaegerOmega
Feb 01, 2022Aspirant
So I have been fighting with this all night. My network "folder" is \\cloud\backup and the network folder is "U". That's supposedly root of the drive. When I even try to select another folder, it is never written to the "folder name" field.
I think there must be a bug in this firmware version (latest V1.0.8.70_2.0.36). I am able to navigate with my file explorer to \\cloud where it does show \backup and even any other shared folders I create but when I try to access it, it says it can't find the location. I even tried through http/ftp and again I am able to get to 'cloud' and see the 'backup' folder but when clicking on the backup folder I get a 404.
Altsai
Feb 07, 2022NETGEAR Expert
>>> did you ever use below DOS command to cleanup the windows neighborhood name?
net use * /delete
