DaveShare's avatar
DaveShare
RAXE500 - Readyshare - Problems with larger HDD
Looking for advice on getting large HDDs to work with readyshare   I have tried the following on my RAXE500   256Gb Samsung SSD in a UGREEN M.2 SATA SSD Enclosure USB 3.0 - Works; no apparent iss...
  • DaveShare's avatar
    Jun 10, 2024
    Posting this in case it helps someone else.
    Changed from the ICY BOX enclosures to a UGREEN 3.5 USB 3.0 enclosure ACBUGN50424.
    Moved over the drives, changed nothing else and WD RED 8Tb drive now running stable for several days with relatively heavy access.
    So in summary an enclosure which worked perfectly on a PC was not stable on the RAXE500 with readyshare.  Changed to a more modern enclosure with same drive, no other changes solved that issue.
