SSP2020
Feb 26, 2025Guide
RAXE500 -Readyshare- Network Drive Add Issue but access the Drive Over Internet
Hi All, I have been using an SSD connected to the USB 3.0 port of my RAXE500 router (Firmware Version V1.0.12.96_2.0.45) and was previously able to: Access it via FTP from outside my network. Add...
- Feb 27, 2025
Solution: First Control Panel>Credentails Manager>Windows Credentails>Delete the Stored Readyshare one.
Open Network and Internet Setting>Change Adaptor Options>Adaptor>Right Click>Properties>Instead of using \\readyshare\, try manually entering different paths:
Press Win + R, then type: \\192.168.1.1 (or your actual router IP). It will ask for the Router username and password. Enter router one and not the Windows one. Don't click on save username and password; otherwise, you will need to clean this again.
Alternative Path Formats to Try:
\\192.168.1.1\ --------- I'm able to access this from Folder Explorer.
\\READYSHARE\ ---- When I entered this, it gave me the same error after entering the router Credentials
Restart Network Discovery & DNS Cache
Open Command Prompt (Admin)
Run the following commands one by one:
net stop dnscache
net start dnscache
net stop fdrespub
net start fdrespub
net stop nlasvc
net start nlasvc
Since I don't want to use the Router IP and More Inclined to the \\readyshare\ path
Router Login>Advanced>USB Functions>ReadySHAREStorage>USB Storage (Advanced Settings)
Network/Device Name: I changed readyshare to readyshares
I am able to access the network driver on the wifi + FTP as well.
Feb 26, 2025Guru - Experienced User
did something change with the network to disable their network security/sharing (ie, changed from private to public) ?
Have you tried re-mapping the drive?
- SSP2020Feb 26, 2025Guide
I have thoroughly reviewed all available information and attempted all suggested solutions. However, the issue persists. At this time, I do not wish to upgrade the firmware to version 1.2.13.100, as it has known issues, including Wi-Fi drops. Please provide an alternative resolution
- michaelkenwardFeb 26, 2025Guru - Experienced User
We'll have to take your word for that. There have been many questions and answers here on ReadySHARE issues.
I recently had new problems with ReadySHARE that tracked back to a Windows update.
Did you find this in your extensive research?
Solved: Re: Readyshare no longer available - asking for cr... - NETGEAR Communities
You have experienced these issues, or are they just something that you have read about?
Disclaimer: Just another user with time on their hands.
Yes, as I mentioned earlier, I have tested this on three different Windows laptops—one running Windows 10 (without updates), one with Windows 10, and another with Windows 11 (which had an update). Unfortunately, in all cases, I am unable to access the ReadySHARE network after entering the username and password. The connection is always refused.
https://community.netgear.com/t5/Nighthawk-Wi-Fi-5-AC-Routers/R7400-Problem-with-Readyshare-and-new-Win-11-laptop/m-p/2405936
https://community.netgear.com/t5/SMART-Wi-Fi-General-and-Legacy/Readyshare-is-not-accessible/td-p/1143983
https://community.netgear.com/t5/Nighthawk-with-WiFi-6-AX-and/Readyshare-no-longer-available-asking-for-credentials-but-not/m-p/2409400
https://community.netgear.com/t5/Nighthawk-with-WiFi-6-AX-and/Readyshare-not-working-with-Windows-11/td-p/2327080
https://community.netgear.com/t5/Nighthawk-Wi-Fi-5-AC-Routers/ALL-Netgear-USB-Drive-Mapping-Issues-ReadyShareConnect-exe/m-p/1311880
https://answers.microsoft.com/en-us/windows/forum/all/networking-not-showing-readyshare-connections/14493bbc-54db-4e50-89de-a5f3cb9345d2
https://community.netgear.com/t5/SMART-Wi-Fi-General-and-Legacy/Windows-10-does-not-recognize-USB-Flash-drive-From-Nighthawk/td-p/2363040
